Replicant tests an AI agent in two ways: scenario tests for end-to-end tests, and capability tests that focus on the skills that the bot must exhibit and quickly check that it works correctly for all permutations of that skill.
An AI agent is only as reliable as the tests behind it. Here is what those tests look like, why one kind is not enough, and the questions to ask any vendor.
Why does an AI agent need more testing than ordinary software?
Ordinary software gives the same output for the same input. An AI agent does not. The same caller request produces a different sentence on the next call, and a change that fixes one flow breaks another without raising an error. The failure shows up as a caller who gives up, a payment that does not post, or a transfer that should not have happened.
A code review does not catch that. Tests that play real conversations do. Teams that test by hand skip tests when a launch date gets close, so the tests that matter most are the first to go.
What is a scenario test for an AI agent?
A scenario test plays one complete conversation against the AI agent from greeting to outcome, then checks the result. A journey, meaning one full path a caller takes through the AI agent, becomes one or more scenarios. A caller who spells a street name twice, a caller who changes their mind mid-payment, and a caller who asks for a person on the first turn are three separate scenarios.
Scenarios are written around how callers really talk, so the suite reflects how callers behave, not how a design document assumes they behave. Scenario tests run automatically on every change. A regression test, which checks that a fix did not break existing behavior, runs in the same pipeline, so a mistake fixed once stays fixed.
Capability tests sit beside them. A capability test checks one behavior, such as reading an amount back before charging. Scenario tests tell you the whole call worked; capability tests tell you which behavior broke.
What do live test calls + automated tests catch?
Automated tests prove the AI agent does what the tests describe. A live-person test call proves the AI agent holds up on a real phone line with a real voice, background noise, and a caller who does not follow the script.
Before a customer goes live, the customer’s team and Replicant’s team each call the AI agent from start to finish and complete real tasks. Automated tests and live calls catch different problems. Automated suites find the broken step. Live calls find the awkward pause, the confusing read-back, and the question nobody thought to test.
What does a launch-ready AI agent look like?
Two results, together. The automated suite passes at a high percentage, and live-person test calls complete the full journey. For example: Before one roadside assistance customer's go-live, its AI agent passed an automated suite of almost 2,000 tests across 336 journeys at a 97% pass rate, then completed live-person end-to-end test calls.
Replicant’s automated testing focuses on breadth across every journey and depth within each one while giving you control to decide what passes the test and what needs to be evaluated again.
What happens to testing after launch?
It continues on every change. Every change to a Replicant AI agent goes through a merge request, runs the test suite, ships to a small share of traffic first, and goes to all callers only when the metrics hold. Safer Bot Releases, which is generally available, runs that process. A canary release sends a change to a small share of calls first; if the numbers regress, the earlier version is still running and the rollback is a configuration change.
What should you ask a vendor?
Three questions.
  • How many test scenarios does my AI agent pass before launch, and where did they come from?
  • Does a person call the AI agent on a real phone line before my callers do?
  • What happens to my test suite when you change a prompt?
A vendor who answers with "we try it a few times" is selling a demo.
How do you test an AI agent?
Run scenario tests that play full conversations, capability tests that check single behaviors, and live-person test calls on a real phone line. Run all three on every change, before the AI agent takes customer calls and after.
What is the difference between a scenario test and a regression test?
A scenario test plays one conversation and checks the outcome. A regression test is a scenario or capability test kept in the suite because a past mistake happened there. It fails until the fix ships, and it guards the fix afterward.
Why do AI agents need live-person test calls?
Automated tests check what the team thought to test. A live call on a real phone line checks voice, noise, pauses and read-back with a caller who improvises. Replicant tests an AI agent two ways before launch.
How many tests does an AI agent need?
Enough to cover every journey and the variations within each one. The count follows the AI agent's scope. A narrow agent needs a small suite; an agent with dozens of journeys needs thousands of tests.
How Do You Keep An AI Agent On Script Without Making It Rigid?
What 2.4 Million Retail Calls Show About Order-Status Automation
How Do Outbound AI Agents Avoid Calling The Same Person Twice?
What 1.8 Million Consumer-Lending Calls Show About Loan Servicing Automation
