A contact center that scores a sample of calls is guessing about the rest. Conversation Intelligence, the Replicant product that analyzes recorded conversations, scores every call against your scorecard, groups calls by why people called, and answers questions about them in plain language.
What is Conversation Intelligence?
Conversation intelligence listens to recorded calls, analyzes them, and turns them into data a team can act on. It transcribes each conversation, scores it against criteria you define, and tags it with the reason the caller phoned. A scorecard, meaning the list of behaviors and outcomes a team scores each call against, is the center of it.
The point is coverage. A quality team that listens to 3-5% of the agents’ calls per month sees only a fraction of the work. A system that listens to all of them sees the whole pattern.
Why is sampling not enough?
A sample tells you about the calls in the sample. It cannot tell you how often a problem happens, which team it hits, or whether last month's fix worked.
This matters for three reasons.
- Coaching should reflect an agent’s full work, not which calls got pulled.
- When reviewers score the same call differently, agents stop trusting the feedback.
- A monthly review can report a problem weeks after it started.
Before you change a process, ask what share of the calls the decision rests on. If the answer is a few percent, the decision rests on a guess.
One Replicant customer, CorVel, put it this way: 'Instead of guessing why people are calling based on a fraction of data, we're getting real-time insights across 100% of our calls.' (Cindy Gambosh, Director of Workforce Optimization, CorVel.)
What do scorecards and call reasons do?
A scorecard scores each call the same way, every time. CorVel described the effect: 'You set up the scorecard, and Conversation Intelligence listens to all of your calls, providing a fair and consistent scoring process.'
In the Replicant interface, scorecards can be grouped so results are read by theme, with expanded explanations of why a call scored the way it did. Topics and Reasons group calls by why people called, using categories and the taxonomy of your business, which your team enables and manages.
How does a team ask questions of its calls?
Ask AI lets a team ask a question about its conversations in plain language to uncover trends, gaps, and quantify insights directly from the conversation data, such as:
- "Why are customers calling us?"
- "What are our top call drivers?"
- "What trends are changing over time?"
- "Where are we losing customers?"
This is important because you to get:
- More accurate answers: Get accurate counts, rankings, trends, and time-based analysis to understand what's driving performance.
- Faster Insights: Identify customer issues, opportunities, and emerging trends without manually searching through calls.
- Simplicity: Move from question to answer in seconds with suggested prompts and clear explanations.
What changes when AI agent calls and human calls sit together?
Most contact centers now run two kinds of conversations. People take some calls, and AI agents take others, and the data usually lives in two places. Replicant shows AI agent conversations and human conversations on one Conversations page, so a reason, a score, or a transcript can be found in one search.
One customer, Century Support Services, described the effect on its team: 'Conversation Intelligence is revolutionizing our approach to client-facing agent performance. We're now able to swiftly mine and assess agent and/or team scorecard data.' (Danielle Palmiero, VP Customer Service.)
What should you ask a vendor?
Three questions.
- What share of my calls do you score, and what do you we take action from them?
- Can I define the scorecard and can I see why a call got its score?
- Do AI agent calls and human calls show up in the same place?
A vendor who answers 'a representative sample' is selling a smaller version of what you do today.
What is Conversation Intelligence in a contact center?
Conversation intelligence is software that transcribes and analyzes recorded calls. It scores each call against criteria you define, tags calls with the reason the caller phoned, and lets a team ask questions about the data.
How is scoring every call different from call sampling?
Sampling reviews a few calls and assumes the rest look the same. Scoring every call shows how often each issue happens and which teams it affects, so coaching and process changes rest on the full set of calls.
What is a scorecard?
A scorecard is the list of behaviors and outcomes a team scores each call against, such as whether the agent verified the caller or resolved the request. Scoring every call against the same scorecard keeps results consistent.
Can Conversation Intelligence analyze AI agent calls?
Yes. The Replicant interface shows AI agent conversations and human conversations on one Conversations page.
