An AI agent that talks to your customers should ship the way any critical software does. A change goes through a merge request, runs against a test suite, rolls out to a small slice of traffic as a canary or A/B test, and gets promoted or rolled back based on measured results. That is how every agent change ships on Replicant today. Here is what the process looks like and why it matters more for AI agents than for ordinary code.
Why is releasing an AI agent harder than releasing code?
Because the AI agent is stochastic. The same prompt, configuration, and model can produce a different sentence on the next call. A change that improves one flow can quietly degrade another, and the degradation does not throw an exception; it shows up as a caller who gives up, a payment that did not post, or a transfer that should not have happened. You cannot catch that with a code review. You catch regressions with tests that run real call scenarios, and you limit exposure with releases that send a change to a small, measured share of calls.
What does a release look like on Replicant?
Four stages, every time.
Merge request. Every change to an AI agent, whether a prompt, a workflow step or an integration, is reviewed before it goes live. Each change is recorded against the version it replaces, so reviewers can see exactly what was removed and what was added. Nothing is edited live in production.
Tests in the pipeline. Scenario tests play whole conversations end to end. Capability tests check a single behavior, such as 'reads the amount back before charging.' Tests come from the AI agent's requirements and from real calls: a good call becomes a scenario test that locks the behavior in; a bad call becomes a regression test that fails until the fix ships.
Canary or A/B. The change ships to a defined share of traffic, side by side with the current version, with the metrics that matter for that AI agent (resolution, authentication success, latency, transfer rate) compared between the two.
Promote or roll back. If the numbers hold, the change goes to 100%. If they do not, the previous version is still running and the rollback is a configuration change, not a rebuild.
What does this change for a customer?
Three things.
- Changes arrive faster, because the safety net lets the team ship small and often instead of batching.
- Regressions are rarer and shorter, because a bad change is caught on a slice of calls.
- Every change is answerable: a customer can ask what changed, when, and what the measured effect was, and get a real answer.
What should you ask a vendor?
Can I see the history of changes to my AI agent? How did you test the last change before it reached my callers? What share of my traffic saw it first, and what did you compare it to?
If the honest answer is 'we edited the prompt and watched,' the AI agent is being operated like a demo.
What is a canary release for an AI agent?
A canary ships a change to a small share of live conversations first, monitors the agent's key metrics on that slice, and promotes the change to all traffic only when the metrics hold. If they do not, the change is rolled back and most callers never saw it.
Can you A/B test a voice agent?
Yes. Two versions of the AI agent run side by side on split traffic, and outcome metrics such as resolution rate, authentication success, and latency are compared. It is the most reliable way to know whether a change helped, because the comparison is on real calls in the same period.
How do you run a regression test on a conversational AI agent?
With scenario tests that play full conversations and capability tests that check single behaviors, run on every merge request. The strongest regression tests come from real production calls where the AI agent went wrong, so the same mistake cannot return once fixed.
Does a staged rollout slow down improvements?
It speeds them up. Teams that can roll back safely ship smaller changes more often; teams that cannot batch changes and ship rarely.
