How Do You Keep An AI Agent On Script Without Making It Rigid?
You move the order of steps out of the model and into configuration. With Conversation Paths, the platform decides when an AI agent advances, and the model handles the conversation inside the current step.
Why does an AI agent skip required steps?
A language model that chooses the next task on every turn can choose wrong. A caller who sounds impatient or changes the subject pulls the model toward the topic of the moment, and a required step, such as verifying the caller's identity, gets skipped.
The cost grows with the number of tasks. An AI agent with three tasks has few ways to go wrong. In contrast, an AI agent that manages multiple tasks and different steps for each process (books, changes, cancels, and charges) has many ways to go wrong.
What is a conversation path?
A conversation path is an ordered list of the tasks an AI agent must complete in a call, with rules for moving from one to the next. A task is one unit of work, such as collecting a date of birth or confirming a payment amount. The builder writes the sequence once, in configuration, and the platform enforces it.
What does a path configuration include?
Four things, each one is a rule the platform checks.
- Ordered task sequences, so step two never runs before step one.
- Explicit completion criteria for each step, so the AI agent knows when a step is done.
- Required gates, which block the AI agent from advancing until the criteria are met.
- Structural enforcement, which stops the model from jumping to a task the path does not allow.
The result is a workflow a builder can read, test, and change in one place.
Does a path make the conversation robotic?
No. A path controls sequence, not wording. Inside a step, the model still listens, answers questions, and handles a caller who goes off topic. When the step's criteria are met, the platform moves the call forward.
A useful comparison is a flight checklist. The pilot flies the plane, and the checklist makes sure the gear is down before landing.
Which steps belong behind a gate?
Put a gate in front of any step where a skipped predecessor causes harm:
- Identity verification before any account detail is read aloud.
- Payment amount confirmation before a charge.
- A required disclosure before the caller agrees to anything.
Steps that carry no risk, such as a greeting or a closing question, do not need a gate.
What changes for the people who build and run the AI agent?
Builders spend less time writing instructions that tell a model to remember the order. They define the order, and the platform holds it. Reviewers read one sequence to see what the AI agent is required to do, which makes testing and sign-off simpler.
If you want to see how Conversation Paths works, reach out to our team to show you a demo.
What should you ask a vendor?
Three questions.
- Who decides the next step, the model or the platform?
- What stops the agent from skipping a required step when a caller changes the subject?
- Can I read the whole sequence in one place before the AI agent takes a call?
A vendor who answers 'the model figures it out' is relying on judgment where a rule would hold.
What is Conversation Paths?
Conversation Paths defines the sequence of tasks an AI agent must follow. The platform controls when the AI agent advances and the model completes the current step.
How do you stop an AI agent from skipping steps?
Move the sequence into configuration. Give each step completion criteria, put gates in front of steps that matter, and have the platform block any jump the sequence does not allow.
Does a fixed sequence make an AI agent sound scripted?
No. The sequence sets the order of tasks. The model still chooses its words and responds to the caller inside each step.
