Best Voice AI Approaches to Reduce Call Transfers
The most effective approaches combine intent-based routing to replace rigid IVR menus, direct resolution of repeatable requests instead of routing alone, real-time agent support as an alternative to transferring the call, and continuous call-driver analysis to catch the root causes of repeat contact before they pile up. Which approach to prioritize depends on call volume, complexity, and how much of a given issue can actually be solved without a human.
What causes repeat transfers in the first place?
Before comparing approaches, it's worth being specific about what actually drives transfers, since the fix depends on the cause. The most common root causes are incomplete or incorrect information gathered during the first interaction, issues that genuinely require specialized knowledge the first agent didn't have, technical or system limitations that prevent immediate resolution, process gaps that leave customers confused about next steps, and inconsistent information across different channels or touchpoints. Different causes call for different approaches — a routing problem needs better intent recognition, while an information-access problem needs better agent tooling, not a different routing system.
Approach 1: Intent-based routing vs. traditional IVR menus
Traditional IVRs route based on fixed menu trees: press 1 for billing, press 2 for support, and so on. The problem is that customers often don't know which menu option matches their actual issue, so they guess, land in the wrong queue, and need a transfer to get to the right place. Intent-based routing replaces that menu tree with a conversational AI agent that understands why a customer is calling from natural language and routes them accordingly — to automation, self-service, or the right specialist — without the customer having to guess at a category. This approach directly addresses transfers caused by misrouting, but it doesn't by itself resolve anything; it just gets the customer to the right destination faster.
Approach 2: Full resolution vs. routing alone
This is the more significant distinction. Routing well still requires a human (or further automation) to actually finish the job. Full resolution removes the need for a transfer entirely by having the AI handle the request end-to-end — not just understanding the request, but completing it. The best candidates for this approach are high-volume, predictable requests with minimal exception handling: status checks, simple account updates, appointment changes. For issues that are too complex, variable, or judgment-dependent to fully automate, a well-designed fallback path matters just as much as the automation itself — a smooth handoff with full conversation context, rather than a blind transfer that makes the customer repeat themselves. In practice, most enterprise deployments need both: full resolution for the use cases that qualify, and context-rich escalation for everything else.
Approach 3: Real-time agent support vs. transferring the call
Not every transfer involves AI at all — a lot of repeat contact happens because a human agent lacks the information or authority to resolve something on the spot and has to escalate. An underused approach here is giving agents real-time support instead of a transfer path: internal tools that let an agent get expert input mid-call (through internal chat with a subject matter expert, screen-sharing with a supervisor, or AI-suggested guidance based on the live conversation) rather than passing the customer along. This approach specifically targets transfers caused by knowledge or authority gaps rather than by misrouting or automation limits, and it's often cheaper to implement than it sounds, since it reuses existing staff rather than building new automation.
Approach 4: Continuous call-driver analysis vs. one-time root-cause reviews
Most organizations look for root causes of repeat contact periodically — after a spike in complaints, say, or during a quarterly review. A more effective approach treats this as continuous: using conversation analytics to automatically identify patterns across every interaction rather than a manual sample, flagging when a specific issue is repeatedly driving contact, surfacing where agents consistently need coaching, and identifying new candidates for automation as they emerge. The advantage of continuous analysis over periodic review is speed — a new product issue or policy change that's driving unexpected transfer volume gets caught in days rather than at the next scheduled review.
How do you know which approach to prioritize?
Start with the math on first-call resolution specifically, since it's one of the more direct levers for cost and transfer reduction: improving FCR from 70% to 80% can reduce total call volume and deliver immediate cost savings without any reduction in customer-initiated contacts, since fewer of those contacts turn into a second or third call about the same issue. From there, prioritization comes down to matching the approach to the cause: if misrouting is the dominant problem, intent-based routing is the highest-leverage fix; if the issue is that too few request types are being automated, full resolution of the highest-volume predictable requests will move the needle further than better routing alone; if agents are escalating issues they could resolve with better support, real-time agent tooling addresses that more directly than more automation would. Call volume and complexity matter too — a low-volume, highly variable use case is rarely worth fully automating, while a high-volume, predictable one almost always is.
What metrics should you track when comparing approaches?
First-call resolution itself: (number of issues resolved on first contact ÷ total first contacts) × 100, typically verified by checking whether the customer calls back about the same issue within 5 to 7 days. Containment rate, specifically for automated interactions: the percentage that fully resolve the customer's need without any agent involvement — a low containment rate means customers are starting in automation but still needing an agent, which adds a step rather than removing one. And cost per resolution rather than just cost per call, since a single call that fully resolves an issue costs less than two or three calls addressing the same problem piecemeal.
What's the difference between intent-based routing and a traditional IVR? A traditional IVR routes based on fixed menu options the customer has to navigate and guess their way through. Intent-based routing uses AI to understand what the customer actually needs from natural language and routes them directly, without requiring them to match their issue to a menu category.
Does automating more calls always reduce transfers? Only if the automation actually resolves the request. Automation that merely identifies intent and still hands the customer to a human (a routing improvement) reduces misrouting but not transfer volume overall. Automation that resolves the request end-to-end is what removes the transfer entirely.
How much can improving first-call resolution actually save in call volume? Based on Replicant's analysis, improving FCR from 70% to 80% can reduce total call volume and deliver immediate cost savings without any reduction in customer-initiated contacts, since fewer of those contacts generate a follow-up call about the same issue.
Should agents be given more autonomy to avoid transfers, or should more be automated? Both, depending on the cause. If agents are escalating issues they could resolve with better information or authority, real-time support and expanded autonomy addresses that directly. If the issue is high call volume on predictable, repeatable requests, automation is usually the more scalable fix.
How often should call-driver analysis be done? Continuously, where possible, rather than on a quarterly or ad hoc basis. Automated conversation analysis that flags emerging patterns across every interaction catches new transfer drivers — a policy change, a product issue — much faster than a periodic manual review would.
