The hardest part of a voice conversation is not the conversation. It is the details. A caller can explain their problem clearly, and the AI agent can grasp exactly what they want, but if it mishears one letter in a spelled-out email address or one digit in a street number, the call has failed. Voice AI agents may break at that point, because understanding intent is the easier layer, while names, numbers, and addresses are where small mistakes pile up.
Replicant AI agents get those details right with a layered method: structured collection, read-back and confirmation on every high-stakes field, extra transcription effort only where a mistake would cost something, and a correction model that believes the caller when they say “no, the other one.” Here is how each layer works and what we measure.
Why is entity capture the hard problem in voice AI?
Speech recognition is probabilistic. On a clean studio recording the best systems are excellent. On a phone line, with road noise, an accent, a speakerphone and a caller reading a 12-character account number off a card, every character is a small bet. Letters that rhyme (B, D, E, P, T) collide. Street names are open vocabulary. Email addresses mix words, letters and symbols. And the cost of a miss is asymmetric: a wrong intent gets corrected in the next turn; a wrong account number authenticates the wrong person or posts a payment to the wrong place.
The industry has started publishing benchmarks for exactly this, and the results say what anyone who has run voice in production already knows: a model that hears a single field correctly most of the time is not good enough, and the way to get reliable is to add structure around the model. That structure is the product.
How does a Replicant AI agent collect a high-stakes field?
Four layers, in order.
Typed collection. The AI agent knows whether it is collecting a phone number, a date, a name or a postal code, and it uses collection logic built for that type. Phone numbers get digit grouping and length checks. Dates get calendar validation. Names get phonetic and spelled-letter handling. A ten-digit number that comes back with nine digits is caught before confirmation.
Read-back and confirmation. Every high-stakes value is read back the way a human agent would say it. “A as in apple” sounds like that, and a phone number is spoken in groups. The caller accepts, rejects or corrects. In a Conversation Path, the step cannot advance until that confirmation is stored, so the AI agent never acts on an unconfirmed value.
Selective re-transcription. Streaming transcription handles most of the call. On turns where the caller gives a value that feeds a downstream step, a second, synchronous transcription pass runs on that turn alone. A confidence check can also trigger a spell-it-for-me prompt. Accuracy goes up where errors cost the most, and latency stays low everywhere else.
Honoring corrections. The fastest way to lose a caller’s trust is an AI agent that hears “no, the other address” and proceeds with the first one. Replicant AI agents classify every confirmation response as accept, reject or correct. When the caller corrects a value, the corrected value is the one the AI agent uses. AI agents now detect caller corrections up to 97%.
What do we measure?
Two things, on production calls, validated by hand.
  • How accurately the AI agent hears the caller, measured on real telephony audio rather than clean recordings.
  • How accurately it reads information back, measured on spell-out and read-back of alphanumerics across languages.
Both run as repeatable benchmarks, so a model change or a vendor change is a measured decision instead of a hopeful one.
The numbers we care about are the ones that show up in outcomes: authentication success on the first attempt, repeat-collection rate, and how often a confirmed value was later corrected by a human. Those are what a customer feels.
What should you ask a vendor?
Three questions.
  • How do you confirm a high-stakes field, and can the AI agent act before confirmation is stored?
  • If a caller corrects a value during read-back, which value does the AI agent use?
  • Can I hear a real call, on a real phone line, where someone spells an email address?
A demo on a laptop microphone tells you nothing about the call your customers will have.
How accurate is voice AI at capturing names and addresses?
It depends on the audio and the method. Raw transcription on telephony audio makes character-level errors on open-vocabulary fields like names and street addresses. AI agents built with typed collection, read-back confirmation, and correction handling bring the field-level result to the level a customer will accept; the confirmation step is what converts 'probably right' into 'confirmed by the caller.'
Does read-back make calls longer?
Slightly, on the fields that need it. A confirmation adds a few seconds to the turns where a mistake would cost a transaction or an authentication; it is not applied to every utterance. Callers tolerate a read-back far better than a wrong transaction.
What happens when the caller corrects the AI agent?
The AI agent classifies the response as a correction, replaces the stored value with the corrected one, and reads it back again before proceeding. With Replicant, AI agents detect caller corrections up to 97%.
Can an AI agent spell an email address back correctly in Spanish?
Yes. Speech normalization on read-back handles letter names, symbols and domain conventions per language; it is one of the areas where the read-back benchmark showed the largest gains for non-English callers.
How Do You Keep An AI Agent On Script Without Making It Rigid?
What 2.4 Million Retail Calls Show About Order-Status Automation
How Do Outbound AI Agents Avoid Calling The Same Person Twice?
What 1.8 Million Consumer-Lending Calls Show About Loan Servicing Automation
